Removing Metal Engine Undertray
Octavia Mk 1 2004 2.0 4x4 estate
The rear is attached by 3 bolts and rubber mountings and the sides by 3 torx screws each into the wheelarch plastic guards, but how is the front attached? I can remove all the fixings as described and the front remains securely attached to the valance. There is no sign of any other fixings!
Any help kindly appreciated!
This is perfect! I can get that oil change underway now. Your help has been most appreciated!
  • 11 months later...
does anyone have the pdf for a gasoline engine?
Th2 2.0 is a petrol engine.
The undertray fits both petrol and diesel engines, the only difference is the addition of some sound proofing on the diesel versions (part number as listed in the pdf).
