OCTY Vrs II - Engine no location
Where is the engine no located??, had a look but cant see it anywhere. Do you have to remove engine cover?, if so how?, info needed as registration cert came back with engine no unknown, and I cant find it on the other documentation. The car is a Motorpoint import. Cheers :thumbup:
It should be on the timing belt cover, also might be on the joint between engine and gearbox.
May even be on your big white sticker in the boot/service manual.
It will begin BWA (if it's petrol) or BMN (if it's diesel) and six numbers being a total of nine characters.
Removal of the engine cover depends on petrol or diesel.
Thanks for that, no found:)
