4 stud alloys on a VRS
Question is can it be done, rather fancy some ATS Cups however, they are 15' and only come in 4 stud fitment.
Des
If no can do then I'll probably get my wheels refurbed.
could you not use hubs off a lesser Fabia? If they are 4 stud that is i dont know
I have a lesser Fabia (1.9 Elegance) and its got 5 stud hubs
1.2 might be 4 stud
Why would it be?
All cars built on that platform are 5x100.
I'm after a way to fit 4x100 wheels to my Fabia too, I have a set of Ronal Turbos lying around.
I dont think you can get the convertors to go that way, 4x100 - 5x100 are difficult enough and not all the safe as one of the bolt holes ends up being elongted.
And al Fabias are 5 x 100.
Yep I think it's a lost cause. Nevermind, I'll go for a refurb on the OEM alloys.
Des
Ask on edition 38 they will help you, otherwise you probably need some custom adapters made up and a machine shop
Pretty much every combination of adaptions here: A-DAPT-IT USA Wheel Adapters but as Lummox says 5x100 to 4x100 is a no-no really, unless you get some made up at a machine shop and run about on 3 bolts :P
