A Warning!!!!!!!!!
To anyone who is considering removing the strips of plastic on the doors of there car, make sure the car has factory paint and the cars not been re-sprayed at anypoint! even brand new cars get knocked about and have re-sprayed doors etc.
If u try to take the strips off, u will take the paint off as well! not good as u cant stick the strip back down very easily. Result will be having to take the strip of and having the whole side of your car re-sprayed!
Good way to check if the cars been sprayed is open the door and if u can see any lip on the inside then leave it alone!
Did you heat them up at length with a hairdrier, use dental floss to separate the trim from the sticky and then use meths to remove the remaining goo, or did you use the pull and pray technique?
Oh, and my 9 year old says that the fat bird gag isn't very good :)
