Part numbers required please
I am after part numbers for the following bits. All help greatly appreciated!!
1. Small circular blanking plate that fits into the black plastic trim under the windscreen. It fills the hole in where the windscreen wiper would go on a lhd model.
2. Plastic trim and clips, top section at rear of car holding the headlining in, light grey in colour.
Thanks:thumbup: :thumbup:
1) This trim for a RHD car is either.
1U2 819 447 (left inner cap) or 1U2 819 448 (left outer cap) - as apparently there are 4 caps all the way along that bit of panel, so you need two in total depending on whether you're RHD/LHD - so you'll need whichever one has popped out - Outer one closest to the A pillar, or the one more inside that one. :)
2) I think the clip is (if you can confirm there are 2 at the back holding it in then it is)
6U0 867 299. - There are also 3 clips 1U0 867 280 (for octy hatch) which appear to be something to do with keeping the trim for the rear high level brake light in place - so I don't believe this is the one. :)
Thanks Devon:thumbup:
