Dent in Door :o(
Hi Folks,
Whilst on holiday in the Peak District last week, some inconsiderate f***wit rammed his door into my o/s rear door. Unfortunately this has chipped and dented the door about 2 inches above the waist line, basically in the centre of the door panel :mad: Can anyone recommend a dent remover in the Kent area at all ? Many thanks
You may need to go to a body shop as dent removers won't usually touch it if the paint is damaged.
Make sure you pick a decent body shop - I used one that was supposedly reputable and had won loads of awards but their work was shoddy.
as long as its not creased then chipsaway should be able to sort it. they will fix both the dent and chip so its invisble.
feel for you mate, that are some careless inconsiderate devils about.
I don't know if you are still awaiting your dent to be removed but i am a PDR instructor and i live near Watford if i can help in any way?
Thanks for the info Eddie2, much appreciated :thumbup:
