Is there room for an IC fan on the vrs?
As the post title suggests, is there room for an intercooler fan of some sort, to assist with the flow of air over the IC?
Anyone done it?
Ta
N
do a search for "pikey mods" this will show you how to vent the wheel arch liner to allow better airflow over the IC
don't think anybody has attempted to fit a fan on one though
It'll have to pull alot of air to make a difference a would of thought.
If you don't get it right it will actually impead the airflow and make things worse.
Why don't you go for a water spray a la Subaru!!!
you could look for a small SPAL fan, these are slimline and incredibly efficient fans, also used for italian supercars ;) i picked up a 10" fan for under
I had a look at this a long time ago, trying to avoid the FMIC approach initially. Decided against it in the end, as it's quite a tight area, and you might as well arch vent it or go FMIC.
Venting it is cheap and works pretty well when using it on the road, FMIC is more expensive but works well full stop :D
