Rear Door central locking prob
Door behind driver no longer opens using remote, nor does it open from the inside, so im guessing the c/l motors buggered in that door. :confused:
Anyone had this prob and do you know the approx cost of fixin it?
cheers
i guess not
I had a similar fault in my Passat. Apparently a common fault on them. Some dry joints develop due to vibration/poor soldering. Can be resoldered to fix. :)
Do a search on some of the VW forums.
Big question is can you get to the solenoid thingumy when you cant open the door? is there some trick of getting the cover off ?(i havent looked yet)
