Immobiliser symbol flashing
Hi All,
I have a Fabia 1.9sdi 2002 model. I have been having intermittent problems with the immobiliser symbol flashing on the instrument panel. When flashing the car won't start.
I have been to my local Skoda garage and the inignition barrel was replaced as that was the most likely cause, apparently there is a sensor in the barrel that can go faulty.
£200 later the fault has not been cured.
As it the fault is intermmittent they are not able to pin point the actual problem.
I now feel as if I am throwing good money after bad so to speak.
The car is booked in to get the wiring checked next week but I feel as if this could end up costing more than the car is worth.
I would appreciate any advice on possible fixes or causes?
It is a real shame as I really like this car and when running it goes like a dream.
Thanks in advance,
Mears
I had a similar problem with SWMBO's car for a while.:(
On her car it would start but cutout after about three seconds with the immobiliser light flashing.
I suspect that the transponder in her key may have been faulty & (touching a very large piece of wood) since using the spare key it seems to be ok for several weeks now.:)
Hope I don't tempt fate here ! :eek:
Maybe try using your spare key if you have one ? :cool:
Thanks TD eye,
That was the first thing I tried. It is the same with both sets of keys.
Does any one know how many wires connect the key barrel to the imobiliser?
I think that I will check out the wiring first myself.
Grudge paying £50 per hour for that.
Mears
