Warning Lights and Fault Codes
carisbrook
Hi
Got a Power steering warning light come on the dash(the light with ! mark)on the OH's Fabia(ATD,PD 100,2001).
I've scanned it but no fault codes have shown up bar this ABS fault, any ideas on what both faults are and how I can solve them?
Thanks for any help.
Simon
Tuesday,02,October,2007,18:30:48:42859
VAG-COM Version: Release 704.1
Data version: 20070629
Chassis Type: 5J - Skoda Fabia
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBGS Mileage: 66360km/41234miles
Address 01: Engine Labels: 038-906-019-100.LBL
Part No: 038 906 019 AF
Component: 1,9l R4 EDC 0000SG 1110
Coding: 00002
Shop #: WSC 13765
TMBGS46 SKZ
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: None
Part No: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 13765
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 6Y0 820 045
Component: Klimaanlage X0770
Address 09: Cent. Elect. Labels: None
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25786
Shop #: WSC 13765
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 02
Coding: 12338
Shop #: WSC 13765
Address 17: Instruments Labels: None
Part No: 6Y2 919 870 D
Component: KOMBIINSTRUMENT VDO V09
Coding: 2
Shop #: WSC 25
TMBGS46 SKZ7
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 000
Shop #: WSC 13765
Address 25: Immobilizer Labels: None
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 44: Steering Assist Labels: None
Part No: 6Q0 423 156 G
Component: Lenkhilfe 0004
Coding: 001
Shop #: WSC 00000
Isn't the steering light an amber steering wheel? The ! mark in red is usually a brake warning and from your scan it seems as though the ABS controller is on its' way out. will the fault clear? You may want to edit the VIN and immobiliser serial number from 01 and 17.
Cheers for the tip.missed that!
i've cleared and rescanned after driving, and that scan is the 2nd one today.
Would that be telling me that pads are low?
The ABS controller is that a expensive job?
Cheers Simon
You scanned a 5J (MKII) Fabia however I'm guessing yours is a 6Y MKI Fabia. Don't imagine it matters so much in this case but might be worth noting for next time.
Oops,not doing very well today!
Scanned it again and the same faults appeared.
I looked in the user manual and the steering wheel with ! mark (situated in the rev counter) says Power steering,funny nothing comes up in the scan?
Most hast been said yet, but you should be able to get a new ABS control module (not the whole unit) for ~440 EUR (excl. VAT), that's ~300 GBP I guess...
Alternatively check for used control modules, 6Q0907379A, 6Q0907379D and 6Q0907379H should fit.
Sorry to hi-jack another thread - I have a 53 reg Octy VRS with 45,0000 miles, about a month a go I went to pull out onto a roundabout and the the coughed and felt like it was going to stall.. then recovered and was fine, within the hour the engine warning light came on.
Took it to a local garage, who said the fault code was for a temp sensor - but as the guage & fan etc all seemed to be working fine he just reset the light, all was good - then 2 weeks to the day the light came back on - I took it back to the garage yesterday, and he's now telling me it's warning about 4 things.. so again has reset the light, and told me next time it comes on to take it straight back (picked the car up this morning and the light was back on within a mile.. so will have to take it back after work)
Anyone else had this same problem? - I don't really wan't to start having to replace random sensors and waiting two weeks.. but is there any other way?
Thanks in advance
Graham
There have been plenty of cases of rough running cars. VCDS is capable of displaying nearly 12000 codes across all the control units, so without the codes that your car is showing it would be impossible to tell you what the problem is and will be the only way to avoid replacing random bits and pieces.
