creak from rear suspension
hi i have a creak coming from the back of my car of which has only started to happen since fitting my jabbasport arb. any idea's?
cheers TDI vRS
I recon the spring is not seated in its top mount.
Shaun
sounds like the arb twisting though
Sway bar bushes?
I lifted the rear on my car then put it down and wondered what the creaking was, turned out to be the spring had become unsat at the top. Worth jacking it up and checking as its only a 5 min job.
Shaun
did you grease the ARB bushes with the special grease that comes with the ARB ?
when you tightened the lower shocker bolts when the ARB was fitted , did you tighten them with the vehicle on the floor ?
ye i greased it and slackened and re-tightened whilst on the floor.
