Heaters broken!!
Hello,
My heaters have stopped working, started on the same day that the really cold weather started so been driving in gloves, scarfs, hats etc.
The blowers are working but I'm getting no heat. Any ideas what the cause could be?
My VRS had the heater and blower motors replaced back in May, but the heaters worked then, its just back then they had a mind of their own. I'm wondering if its the same part again?
Rik
could be the same thing again , sit in the car ,put the heater control to cold, then turn the ignition on (don't start the engine) now turn the heat control to hot , you should be able to hear the motor working , if not it could be stuck or broken
if they were only done in May this year , they should still be under warranty
