No messages from Nexus in Maxidot
Hi all
I just returned from my friendly Skoda dealers where i had my cluster swapped for a new RS one with MaxiDOT.
The immo and key learning went ok, but now I don't get messages from my Nexus in the display.
In the menu I can choose between MFD, Phone (Original BT) and Setup - in my old car which was factory fitted with MaxiDOT I also had Audio and Navigation.
Any hints? It is probably to do with the coding, as the guy who helped me wasn't too familiar with the 5051 tester.
Greetings from Denmark
Jan
As I said in your PM, the Autoscan will be the clue. Either post it here or email it to me and I'll take a look.
I'm picking up VAG-COM this afternoon
Right, so here is the Autoscan - in Danish, i'm afraid....
Torsdag,28,Juni,2007,15:49:29:9143
VAG-COM version: NEZ 704.1
Dataversion: 20070606
Modeltype: 1K0
Styreenheder søgt: 01 03 04 08 09 15 16 17 19 25 37 42 44 46 52 56 62 69 72 76
77
Stelnummer: TMBGE61Z482064XXX Kilometerstand: 300km/186miles
01- Motor -- Status: Ok 0000
03- ABS bremser -- Status: Ok 0000
04- Styrevinkel -- Status: Ok 0000
08- Klimaanlæg -- Status: Ok 0000
09- Centralelektrik -- Status: Ok 0000
15- Airbags -- Status: Ok 0000
16- Ratelektronik -- Status: Ok 0000
17- Instrument -- Status: Ok 0000
19- CAN Gateway -- Status: Ok 0000
25- Startspærre -- Status: Ok 0000
37- Navigation -- Status: Ok 0000
42- Dørelektr., V for -- Status: Ok 0000
44- Servostyring -- Status: Ok 0000
46- Komfortelektronik -- Status: Ok 0000
52- Dørelektr., H for -- Status: Ok 0000
56- Radio -- Status: Ok 0000
62- Dørelektr. V bag -- Status: Ok 0000
69- Anhængertræk -- Status: Ok 0000
72- Dørelektr. H bag -- Status: Ok 0000
76- Parkeringshjælp -- Status: Ok 0000
77- Telefon -- Status: Ok 0000
Styreenhed 01: Motor Forklaringsfil: 03G-906-016-BKD.LBL
Styreenhedsnr. SW: 03G 906 021 LD HW: 03G 906 021 LD
Komponent : R4 2,0L EDC G000SG 9184
Kodning : 0000072
Forhandler : WSC 73430
Ingen fejlkoder fundet.
Readiness: 0 0 0 0 0
Styreenhed 03: ABS bremser Forklaringsfil: 1K0-907-379-MK60-F.LBL
Styreenhedsnr. SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Komponent : ESP FRONT MK60 0101
Kodning : 0023170
Styreenhed 08: Klimaanlæg Forklaringsfil: 1K0-907-044.LBL
Styreenhedsnr. SW: 1Z0 907 044 S HW: 1Z0 907 044 S
Komponent : ClimatronicPQ35 110 0402
Styreenhed 09: Centralelektrik Forklaringsfil: 3C0-937-049.LBL
Styreenhedsnr. SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Komponent : Bordnetz-SG H54 2202
Kodning : 09888F030004140000110D000000000000097F075C000000000000000000
Styreenhedsnr. : 1Z1 955 119 C
Komponent : Wischer 260907 022 0601
Kodning : 00055223
Styreenhed 15: Airbags Forklaringsfil: 1K0-909-605-VW8.LBL
Styreenhedsnr. SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Komponent : Q2 AIRBAG VW8 027 0900
Kodning : 0020786
Styreenhed 16: Ratelektronik Forklaringsfil: 1K0-953-549.LBL
Styreenhedsnr. SW: 1K0 953 549 AK HW: 1K0 953 549 AK
Komponent : J0527 036 0070
Kodning : 0002042
Forhandler : WSC 30000
Styreenhedsnr. : XXXXXXXXXXX
Komponent : E0221 002 0010
Styreenhed 17: Instrument Forklaringsfil: 1K0-920-xxx-17.LBL
Styreenhedsnr. SW: 1Z0 920 842 E HW: 1Z0 920 842 E
Komponent : KOMBIINSTRUMENT VD1 1612
Kodning : 0003101
Forhandler : WSC 00354
Styreenhed 19: CAN Gateway Forklaringsfil: 1K0-907-530.LBL
Styreenhedsnr. SW: 1K0 907 530 L HW: 1K0 907 951
Komponent : J533 Gateway H07 0052
Kodning : E9807F4E4006022302
Styreenhed 25: Startspærre Forklaringsfil: 1K0-920-xxx-25.LBL
Komponent : IMMO VD1 1612
Styreenhed 37: Navigation Forklaringsfil: Ingen
Styreenhedsnr. : 1Z0 919 887 B
Komponent : Navigation 0412
Kodning : 0000002
Styreenhed 42: Dørelektr., V for Forklaringsfil: 1K0-959-701-MIN3.LBL
Styreenhedsnr. SW: 1T0 959 701 D HW: 1T0 959 701 D
Komponent : Tuer-SG 006 1203
Kodning : 0000246
Styreenhed 44: Servostyring Forklaringsfil: 1Kx-909-14x.LBL
Styreenhedsnr. : 1K1 909 144 M
Komponent : EPS_ZFLS Kl.069 H08 1901
Styreenhed 46: Komfortelektronik Forklaringsfil: 1K0-959-433-46.LBL
Styreenhedsnr. SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Komponent : KSG PQ35 G2 020 0204
Kodning : 80801A085283007F3F04850540084FD6907CA0
Styreenhedsnr. : 1Z0 951 171 A
Komponent : NeigungsSensor 009 5003
Kodning : 00000000
Styreenhedsnr. : 1K0 951 605 D
Komponent : LIN BACKUP HORN H07 9001
Komponent : Innenraumueberw.009 5003
Styreenhed 52: Dørelektr., H for Forklaringsfil: 1K0-959-702-MIN3.LBL
Styreenhedsnr. SW: 1T0 959 702 D HW: 1T0 959 702 D
Kodning : 0000246
Styreenhed 56: Radio Forklaringsfil: 1T0-035-095.LBL
Styreenhedsnr. : 1T0 035 095
Komponent : Radio 0412
Kodning : 0004400
Styreenhed 62: Dørelektr. V bag Forklaringsfil: Ingen
Styreenhedsnr. SW: 1K0 959 703 J HW: 1K0 959 703 J
Komponent : Tuer-SG 006 1201
Kodning : 0000144
Styreenhed 69: Anhængertræk Forklaringsfil: 8P0-907-383-69.LBL
Styreenhedsnr. SW: 1K0 907 383 HW: 1K0 907 383
Komponent : ANHAENGERELEKTR 003 0020
Kodning : 0000001
Forhandler : WSC 00000
Styreenhed 72: Dørelektr. H bag Forklaringsfil: Ingen
Styreenhedsnr. SW: 1K0 959 704 J HW: 1K0 959 704 J
Kodning : 0000144
Styreenhed 76: Parkeringshjælp Forklaringsfil: 1Z0-919-283.LBL
Styreenhedsnr. SW: 1Z0 919 283 C HW: 1Z0 919 283 C
Komponent : Parkhilfe 8-Kan H04 0020
Kodning : 0010011
Styreenhed 77: Telefon Forklaringsfil: 5P0-862-335.LBL
Styreenhedsnr. SW: 5P0 862 335 C HW: 5P0 862 335 C
Komponent : FSE_2P5x H24 0100
Kodning : 0000402
End --------------------------------------------------------------------------------------------------
From what I can make out the Coding looks ok.
I'm assuming that you have the MFD2/Nexus switched on when you are looking for the menu.
Yes i do.....
I've been trying to defrag the coding for the CAN-GW and i think it looks all wrong.
Byte 0 bit 2 and 4 aren't set which means i have no ABS or Airbags
On the other hand bit 6 and 7 are set indicating Xenon and all wheel drive
And there are lots more errors. Does that mean anything?
So i went and did a long coding of Byte 3 bit 7 - Telephone fitted, but no luck
Yessss.....!!!! Found it
Aparentley you have to code the radio to use a cd-changer when using the original iPod interface from VW
Now everything works....
Should I clean up the coding on the CAN-GW? It is totally f**** up.
Yes you do need to have it coded for a CD changer with the Ipod interface.
The autoscan you posted doesn't show any faults so I'm a little confused why you think it is wrong.
Since your basic problem has been solved (coding it for cd-changer is correct), allow me to comment on your gateway coding.
Depending on the year/make and model the gateway coding may vary depending on control module part number and software version. This problem has been this way for quite some time and until now VAG-COM did not have a way to determine that by itself, but we did have the long coding helper/assistant which gave you the right information anyway. We haven't had a chance yet to put the current gateway coding scheme online in our WIKI, so I will take care of that within the next couple of hours.
VW Golf (1K) CAN-Gateway - Ross-Tech Wiki
