engine problem...
Hy!
Im new here and not good in english. I hope you will understand my problem with fabia that i have.
So i have Fabia 1,4mpi/50kw, ATZ.
Every morning when i start the engine and i press gas pedal the engine runs on 500/min...or lower and then engine switch off. If i dont tuch the gas pedal the engine runs on 850/min or higher. And than i start it again and it works fine. If i dont touch the gas pedal for 5 minutes then i can drive normaly.
If i wait 30...60 second than i have this problems. This is happening when the engine is cold. When is worm than is no problem.
I hope you know what i mean.
Please give me some solution.
The lambda is new and sensor G62 to.
The VAG-COM is showing No Faults!
Best regards
Is G62 the coolant sensor?
If not, try a new coolant sensor. Also try cleaning the throttle body and perform an adaption with VAG-COM.
Yes G62 is the coolant sensor that i change it.
I cleaned the flap-throttle body.
What did you mean adaption with VAG-COM?
I have vag-com cable, can i do it my selfe?
