octavia cam belt change hellllppp
hi there im just trying to find instructions to replace the cam belt on a skoda actavia 1.8 20 v 2000 in case there are any hidden suprises, it will be a driveway job.many thanks ali
Welcome Ali, I've moved your question to the correct forum.
We do have a seperate forum which is supported by a couple of very accomplished Technicians who may be able to help.
To access this area you would need to be a Freedom Member.
Haynes manuals are very helpful.I believe you will need a m5 bolt to take the tension off the belt to get it off and also something to lift the engine up off the engine mount
