Sport front damper replacement
Does anyone know if any bolts etc should be renewed when replacing the front dampers. Also does anyone know the torque settings for refitting.....many thanks....
Suspension strut to wheel-bearing
housing - 70 Nm + 90°
♦ Use new nut
♦ the tip of bolt must point in the direction of travel
Suspension strut to body - 15 Nm + 90°
♦ Use new screws
Steering joint to track control arm - 75 Nm
Coupling rod to suspension strut - 65 Nm
♦ Use new nuts
♦ Counterhold at hexagon socket of
pivot pin
Wheel bolts - 120 Nm
cheers Stu,,,did you get my email???? same question....through your site...
Yes I did but it's on my other machine so I posted it here and intended to email you to that effect. I got towo actually, slightly different address's
