How to enable extra wipe using VAG-COM?
As per the title how do I enable the extra wipe after using the washer? I have VAG-COM.
I was about to say I'm sure I've posted it. I'll add it here for the benefit of others -
Fabia is Controller 09 - Login 21343
Adaption 10
Channel 07
5 is default on and 0 is off.
Is final wipe dependent on the version of convenience Stu, a bit like one-touch indicators?
Steve
I'm not 100% steve, certainly worth a look.
Oky doke - I shall investigate next time I'm connected :)
Steve
I recently went through this because a customer complained that the known scheme did not work for him. Please see the updated WIKI page for which channel to use and if the login is needed - based on the control module part number.
VW Polo (9N) Central Electronics - Ross-Tech Wiki
A current version of VAG-COM "should" already cover this problem appropriately and show the right info in the right spot.
That work a treat Stu! Thanks a million :D
