Wind deflectors Octavia II
Just bought a pair of genuine wind deflectors for my 2006 Octavia. The problem is on the fitting instructions it says it must be at least 20 celsius befor they can be fitted. Is this correct? :eek:
its probably for the glue if it has sticky bits. could you heat it with a hairdryer?
May try that in the garage.
Either that or its to stop you snapping them in 2 if it needs to be bent to slot in :)
