Octavia - door locks
Hi,
I'm having the following problem, sometimes when i`m in the car i hear a clicking sound from inside the dashboard drivers side, when this happens the locks fail to engage. it seems as if the relay is having problems.
when i lock or unlock the car from the outside i never have problems only from the inside.
Another issue is that some time the rear left passanger door locks and then unlocks when the lock button is pressed and i have to manually lock the door.
has anyone had the same problems?
where can i get the electrical diagrams for my car?
thanks in advance
The convenience unit is located there as well, have you had it scanned for any fault codes?
I havent scanned the car yet, will do it this week end. but today the power windows ,the power locks and mirrors stop working for a moment. the driver buttons didnt work, and i had to press the button on each door to close the windows. then after a while everything was ok.
PROBLEM SOLVED!!!! i disconnected the drivers window module and the annoying clicking noise disappeared. i cleaned the contacts and put it back together and it is working well. and the best off all is that i solved it without any cost at all jejejeje, here in my country the spare parts are very expensive.
