Indicator relay clicking when not turned on?
Hi, I have a TDi L&K estate on a 02. The fault I have is it sounds like the indicators are on when it is not. Could it be a relay on the blink, the indicators work ok, but there is this intermittent sound which can be slow or fast, as through a relay is clicking on and off.
Where is it located, if it is a relay, and can you get to it easily?
Hope someone can help
Shappy
mine does this on and off and i changed the relay and it was the same - sometimes it is ok for weeks and then it does it all the time - not sure of what it is yet but think it could be the stalk contacts ??
From the same thread in the Octavia 2 section:
It won't be the relay, as when these fail the indicators flash very slowly or not at all when the switch is operated. The relay clicking without the switch been operated will be a stalk switch fault, first off spray some switch cleaner into it and work it in to see if it improves. The fix would be to replace the switch which is a steering wheel and airbag out job. The price of a normal switch without cruise control is around £35, I think that the cruise control one will be more.
