Headlights Dim on 1998 Felicia 1.3L
I have a 1.3L 1998 Felicia, and recently noticed that sometimes the Headlights cut out/go very dim when changing gear. Has anyone got any ideas what this could be caused by? Cheers, and keep on trucking skoda fans:O
Your alternator drive belt may not be tight enough (hence less power when changing gear) - that or another problem with the alternator like the voltage regulator.
i would think it is your alternator on it way out
Keep yur revs up when you change gear ;) (Joke)
Is your car hard to start?
Is the alternator charging battery light glowing at low revs?
Make sure the electrolyte levels in your battery are correct - use de-ionised water to refill it if they're low.
I agree that it could be the ancilliary drive belt loose, though lights are bright (usually) without the engine running at all...
Thanks for the help!!!!:) I'm checking out the Alternator and battery!
