New oil Sump
my felicia 1.9 D needs a new oil sump :( anyone got any idea if its hard 2 replace and the cost??? thanks
dont ask how i did it.............................on the driving test i got cut up and had to drive onto verge and scraped the sump , but i didnt fail on that...............i failed coz i made abusive signs to the other driver lol
Hi and welcome to Briskoda :D
I know nothing of the 1.9d, however looking at the parts catalogue...
Call up your local Skoda sdealers parts department and ask them how much part number 028 103 601 E is (this is the 1.9 diesel sump). It may then be worth shopping around, I don't know if GSF would sell them, it could also be worth giving Jorily Skoda on ebay a buzz to see if he's got any.
According to the parts catalogue it's held on with 20 m6 self-locking hex bolts.
There's also a "baffle" part number 037 115 220 B, not a clue what this does. I wonder if it's the equivalent of the sump gasket. You may need one of those too.
May be worth your whlile getting a haynes manual.
Hi & welcome pottheed :rolleyes:;)
:lol: @ why you failed your test, sad tho it is :(
Sump removal on the diesel gets a 2 spanner rating according to Haynes, so if you can service your car including the brakes & have a torque wrench you can probably do it yourself (the engine doesn't have to come out).
The baffle, as mentioned above, is a piece of steel plate in the sump to stop the engine oil splashing and surging around and to keep it around the oil pickup. If your sump is badly damaged then the baffle may be damaged too.
Get a Haynes :thumbup:
You can buy the baffle plate seperate if needed
