readiness test fails
while browsing through my handheld VAGCOM jobber i went into the readiness test menu. most of them came up as failures. such as the cat and oxygen sensor. is this just due to the fact that the engine is totally cold (hasnt been run for a couple of days), and all those components arnt at their operating temps??
ill take it for a quick drive and get everything up to temp and run the test again............
NOTE: the only error code i had was the one that reads "pressure drop between turbo and throttle valve *check DV*". I wonder if this is putting the emmissions systems off?......
anyone know about this? :jab:
Are you sure you dont want those cable ties.......................................LOL
Sorry, but could not resist it.
hahaha cheers buddy!!:dopey:
yeah all passed today.
exept from "sec. air pump". what the hell is that?!
everythings fine now! no engine error codes. no fails.
is it sane to talk to yourself..............
