disable 'bulb out' warning
I have LED brake & side lights. I'm getting two messages, bulb failure and brake light failure. I don't know if they relate to the same (brake light) or to the sidelights as well.
Has anyone disabled the warning via vag-com or otherwise or is it a power resistor add in I need? I may just do that anyhow as I'm getting a slight currnt flow glowing the light when off (common on led bulbs which will glow with a trace of a voltage)
Greg.
