Fabia, Window washer fuse?
Hi all,
On my drive into work this morning my window wipers and washers stopped working, it was about -2 degrees so not a major issue, At least it wasnt raining.
Anyway. I have swapped over fuse number 13 with 15. (Reverse light and window wiper)
So now the wipers are working, but Still no window wash? I dont think the water is frozen, as I just put in lots of antifreeze yestrday, but should I be able to hear a pump fire up?
Can any one help? I cant see a fuse labled for washer motor or anything like that?
Hi, I dunno if its anything to do with the weather but my fuse went too. Its fuse number 21 5A, but I replaced it with a 10A
ahh cool, thanks for that.
I will swap it over at lunch time and see what happens...
Isnt swapping 5A for a 10A a bit risky?
Its the only one I have and cant be bothered going for another stupid mini blade fuse. The diagram in the manual is the reverse of the fuse box if you get me. Just read the numbers if you can there tiny.
yep, all sorted whatever i did in the semi dark this morning weemed to work, the water must have been frozen because it is all working now.
I just need to get a new fuse for the reverse light. I only need that when parking at work so should be fine till the weekend.
I spotted the reverse diagram as well. very sneeky of them.
Good good, Glad your sorted
