Chatter sound using a Recirculating Dump Valve
Hi
Is there away to make a Octavia Vrs make the chatter sound using a recirculating dump valve.
Jay
no.
But junking the VAG ECU and going aftermarket will LOL
If you can eventually make it make the chatter sound, that means it's not connected properly :)
The chatter is usually the wastegate not the dump valve iirc
And it ain't healthy for your car if it does it so I am led to belive
its not the wastegate either.
Its the air coming back through the inlet tract and hitting the compressor blades and that makes the noise.
That doesn't sound healthy!
Alot depends on the size of the turbo and the shaft.
a T34 Garrett turbo is usually fine.
