DSG re-map is it possible
I can remember reading some where that the 2.0PD engine with DSG can't be re-mapped because the clutches can't handle the torque.
Is this correct.
It's just that I've seen one in my price range but I will be wanting to re-map in the future.
yeah the DSG has much lower torque limits than the manual or normal auto's but a quick google should find the normally accepted limits and then see if its worth remapping as with a custom map they could keep under this torque limit yet gain decent power by gaining more torque at the top end :)
They can be remapped, and its well worth it !!
All the mapper has to do is peg back the old lb/ft (I think 180 lb/ft is the max limit).....
think max recommended torque for the DSG is 250lb/ft and standard 2.0tdi is 236
thanks everyone
p.s how do you convert NM to ib/ft?
Nm -> lb ft = multiply by 0.7376
lb ft -> Nm = multiply by 1.3558
Chris
