Dash bulbs!
Hi all, can anyone tell me how to get the clocks out to replace bulbs for different colour!
Cheers all:thumbup:
Anyone???
They aren't bulbs in the clocks, they are surface mounted leds and are very difficult to replace.
Pull the trim off above the steering column shroud, remove the 2 screws holding the panel in and it will come out far enough for you to disconnect the 2 plugs.
It has been done in the past, in my opinion the risks far outweigh the gains. The dash panel contains the immobilser and it is important in facilitating communications with just about every other control unit on the car. Mess it up with an errant bit of solder or an excess of heat and you could end up with a driveway paperweight which will cost £100s to put right.
gotta say i like the idea of the blue dash tht vw use. i had it in my old lupo
