CAN: not ready
Very Good day to all,
i connected my cable to the car and the result was as below:
Port status: OK
interface:found!
type: ross-tech HEX-COM+CAN
version:1.78
status:ready
k1:OK
k2:OK
CAN: not ready
should i be worried when CAN is not ready i don't know it is normal or that i can't use vag-com with my car?
:confused:
can any one tell me how to check my diesel pump for fult codes?
Looking at your username (You don't state your car) I would suggest that it is perfectly normal if you have a 2002 TDI
Right Stu, that car has no CAN based diagnostics. Everything is on the K lines.
using the vagcom i found the following...
2 Faults Found:
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: N/A
can any one help ... my car does not have an airbag at all...
The Ross Tech guys can help you more if you post a full autoscan.
Clear the faults and see if they return. I have never seen an Octavia without airbags.
hi,
i have seen an octavia without an airbag cos i own it ....
here is the AutoScan result...
Thursday,17,January,2008,08:02:07:63016
VAG-COM Version: Release 704.1
Data version: 20071016
XXXXXXXXXXXX
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 29 35 36 37 39 46 56 76
VIN: TMBCG01U822545543 Mileage: 416830km/259006miles
Address 01: Engine Labels: 038-906-012.LBL
Part No: 038 906 012 F
Component: 1,9l R4 EDC 0000SG 3331
Coding: 00005
Shop #: WSC 31480
TMBCG01U822545543 SKZ7Z0A1009021
2 Faults Found:
P1557 - 35-00 - -
Readiness: N/A
Address 17: Instruments Labels: 1U0-920-xxx-17.LBL
Part No: 1U0 920 811 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 18002
Shop #: WSC 12345
No fault code found.
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00000
Shop #: WSC 31480
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Part No: 1C0 959 799
Component: 3P Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 31480
Part No: 1U4959801D
Component: 3P Tõrsteuer.FS KLO 0003
Part No: 1U4959802D
Component: 3P Tõrsteuer.BF KLO 0002
Part No: 1U0959811D
Component: 3P Tõrsteuer.HL KLO 0002
Part No: 1U0959812D
Component: 3P Tõrsteuer.HR KLO 0002
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: None
Part No: 1U0 035 160 B
Component: Radio 0006
Coding: 00401
Shop #: WSC 31480
5 Faults Found:
00878 - Connection to Speaker Front Left
44-10 - Short Circuit - Intermittent
00879 - Connection to Speaker Front Right
00880 - Connection to Speaker Rear Left
00881 - Connection to Speaker Rear Right
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
Please do a test by going to [Options][Test] and post the results. There are several modules missing. I'd like to see if both K-lines are operating.
i did...
both are operating
The Octavia (1U) only uses the 1st k-line, from that side everything is fine. Based on the gateway coding the car does not have abs or airbags, which means besides the ECU searching for one I don't see anything wrong.
