Help ! Fish eyes head light(halogen bulb) part's No.
Hello :
some body know Fish eyes head light(halogen bulb) for 2006.06 2.0FSI OCTAVIA Part's number ??(right side & left side)
This type head light support level adjust ??
:confused::confused::confused:
not to sure I understand the question, but the bulbs are standard H7 type bulbs and they have a manual headlight level control on the dash.
assuming you mean the projector headlight for the low beam?
If by fish eye you mean the one behind a projector it's a H7
sorry, is this head light set (H7)
No that is the headlight cluster.
The bulbs that fit inside of that cluster are:
- Dipped beam, behind the projector lens - type H7
- Main beam, in the reflector towards the centre - type H1.
Are you after a part number for the entire head light cluster and if so are you after it for right or left hand drive, or just what type of bulb to fit.
for Left hand driver
So if I have this correct you want the part numbers for the whole light cluster (not the bulbs) for both lights for a left hand drive vehicle?
Yes ...
For Halogen Bulbs with the headlight adjuster included or for Xenon bulbs?
I'd check back this evening as hopefully people with access to the software will have seen this post by then and can get you a part number.
Thank you very much
