ipod for vrs tdi
howde just got the cable 2 go from ipod 2the connection in car does anyone know how 2 get the ipod 2 work through the car looked at the manual but no joy maybe im just thick.....plus i hate reading on how 2 get things 2 work so any help is much appreciated thanks conor.
push cd button until u get "AUX IN" and u should be able to hear your ipod play,might have to adjust the level to 3,volume is a bit low I would say.
If you have the cable to connect into the aux socket (the one in the front arm rest), then all you need to do, is plug one end of the cable into the aux socket and one into the ipod headphone jack. Then go into your stereo menu and scroll through the screens until you get to the option to turn on aux, then turn it on!
Then press the cd button untiil aux appears on the display. You should then be in business! There are a few different volume levels for the aux setting in the menu, I find that level 2 works best with an ipod.
Hope this helps.
thats the buisness thanks for the quick response cheers conor.:thumbup:
