Load rating on HU feed or Ciggi Lighter
  • Administrators
Further to the last post, do you ICE men reckon the HU feed (doubtfull) or ciggi lighter would take a upto 80W circa 5amps draw for extended periods of time (read each and every time ignition is on). Or should I really be considering running a seperate 5A fused #gauge cable through the bulkhead?
5amps should be fine, but the cigarette lighter should not be used for that long a period. I had my cool box plugged in for approx an hour and the lighter plug was getting hot. If you need a decent feed then the battery is the best place. If not from the battery then from the main feed into the fusebox. I think fag lighters are rated at approx 10amp max for internediate periods.
Andy
  • Administrators
Thanks Andy,
Can I call you about a few bit's and bobs please ;)
  • Administrators
It maybe a long phone call ;)
Colin, no problem. Either work on 0208 590 1631 between 9.30 and 6.00 or anytime within reason on 07970 939792 (Orange)
Andy
