Fabia 1.4 Excessive Petrol Consumption
Hello,
I have a problem with a fabia 1.4 coming up to 5 years old.
Normaly I put about £30 petrol in and it does me a week.
At the moment It is supping juice like no tomorrow, I am putting in £20 every other day covering exactly the same mileage as I have always done.
It has always been serviced by a Skoda main dealer until the last year when I just changed the oild and spark plugs
The dealership the car was bought from are unfortunatly not only incompitent but downright disshonest charging over £400 for work that was supposed to have been doen but wasnt.
I am thinking it might be the petrol pump giving out.
I have replaced the petrol pump on an old Citroen CV by myslef , which was relatively simple but never attempted anything like that on a modern car such as a Fabia.
Any helpfull suggestions appreciated.
Hello,
Hi optomen
If you're using that much fuel you must have a fuel leak somewhere!!. I can't imagine it being the fuel pump.
You need to take it to a garage that has good diagnostic equipment so they can see what's going on.
wonky
Hello optomen and welcome.
I can't help, but am thinking that if you say whereabouts you are, someone nearby might be able to suggest a good garage. There is a "dealer reviews" section on Briskoda, though it'd probably be better to get a recent recommendation if possible.
Regards
Mo
I'd recommend getting another garage to run a diagnostics. If you know someone with VAG-COM, they can do a check for you (VAG-COM is the diagnostics software sold by Rosstech for end users).
Which 1.4 is it? 8 or 16 valve? Being computerised, it's highly likely that there will be an error message in the diagnostic logs which will guide you to where the problem lies.
Thanks for the PM, Mo :)
