Spacers anyone?
Bought my car last year with dealer fit 'B14' alloys 8J x 18" ET45 that give it really good handling in the dry and a lovely wide stance (track width) as seen here;-
Around Christmas bought myself a set of 'Winter Wheels' being 7J x 17" ET54 'Pegasus' alloys from an Octy Sport to give more responsive wet/cold handling, taller sidewall for more forgiving feel and 2.5kg lighter for less unsprung weight.
Only snag is that they sit a fair bit 'inboard' within the wheel arches as seen here;-
I checked out some other Octys, my dealer had an Elegance with Pegasus wheels on the forecourt and the inboard wheel position was the same. I decided I need to widen the track, for handling improvement and also to restore the 'wide track' stance of the B14s.
Did a load of research, measuring and calculations and decided that 15mm hubcentric spacers would do the trick. They couldn't be slimmer as the wheel would fall off the hub and any wider and the wheels would be outside the line of the wheel arches. Bought a set of Eibach Pro-Spacers with longer bolts from Demon Tweeks, as here;-
Pro-Spacer Aluminium Wheel Spacers | Wheel Spacers | Demon Tweeks Motorsport, Motorcycle, Modifying, Parts and Accessories
.... and lo and behold the car feels and looks great once again;-
A highly recommended mods for anyone with Pegasus, or even other 16"/17", wheels.
dont mean to sound dumb but never used or seen spacers used before. how the foook do they fit on or how do your wheels fit on afterwards
Sandwich between the Wheel and Hub
Longer bolts, generally longer by the size of the spacer, ensure they are held on...
MASSIVE difference :thumbup:, I hate it when wheels are hidden away in the arches, my black combi makes it even worse :thumbdwn:
Whats the situation with insurance and such like?
It's amazing what a difference 15mm can make :rofl:
what's the situation with insurance and such like?
Can't make any difference I would have thought; all I've done is got the wheels in the same place as with the B14s. Wheels are OE kit anyway.
Its not like I've gone and put a set of 20" wheels with dodgy offset on!
Looks really good with them sat level with the bodywork BTW.
Still unsure of the wheels themselves though...
Fair enoughski :)
I think I'll get me a set before I go mad and plump for new alloys.
Fair enoughski :)
Remind me; what wheels do you have at present? Do you know their offset, ET**?
What length and make of wheel bolts did you go with in the end Guy?
7Jx17" Sputniks but I don't know the offset of them but the wheels do sit quite inboard, I would guess the ET is fairly high. It looks even more apparent than with the Pegasus wheels.
OE bolts are 27mm so with +15mm for the spacers = 42; plus a bit for good measure - I bought 45mm bolts (no particular make, just what Demon Tweeks had, shiny zinc finish although the OE wheel nut caps fit over them OK.
I also got a set of 45mm McGard 'lockers' to protect my investment!
If you get the chance, take a wheel off and you will find the size 7J x 17 ET** embossed on the inside face of the wheel.
Alternatively has someone got a parts catalogue they can look them up in?
PS> I know the 'Sputnicks' are a bit of a bu**** to clean but their finish/colour is IMHO pretty good; spacers could be a worthwhile alternative to new wheels for you.
You'd be suprised what a difference it makes. Even changing your wheels to none standard should be notified to your insurer irrexpective of if they're bigger or smaller.
I'd definitely say you should notify them if you're using spacers.
I finally got round to removing the wheels for their big 6 monthly clean and the offset is 7J x 17 ET54.
Same offset as the 'Pegasus' wheels I have.
15mm spacers should suit you nicely. :D and give the same effect as mine. :thumbup:
Excellent, thanks for that :thumbup:
Would that give an equivalent offset of 39mm?
I'll get the spacers somehow. Question is how to get it approved by the 'War department' (a.k.a. SWMBO) :rolleyes:
Another question:
Is it worth getting the alignment/camber checked out after fitting the spacers?
I think I have a rear camber issue on my combi (shock horror!) and spacers will only make the camber problem worse.
make sure you check the bolts regularly.. have snapped a number of DT wheel bolts in the past... admittedly running slicks but even so worth a check!
I guess so; 54 - 15 = 39. The B14s I have are ET 45, so 6mm difference that is just about noticeable.
Good luck
Another question:
I think the difference with having this size of spacer, considering you are only really replicating the fitment of OE 18" rims, will be negligible; but if you think you have a rear camber issue I'd get it checked anyway.
Car looks mint Guy... nice to see that so much thought goes into keeping it look spot on, even when running winter wheels :thumbup:
how many spacers are coming in a set?
2 or 4?
2 or 4?
They come in pairs.
They come in pairs.
Correct; sometimes referred to as an 'axle set'.
Be careful when looking up availability as often the measurement quoted is the increased width for the axle i.e. a pair of 15mm spacers (as I have) are quoted as 30mm (for the axle, total increase in track width).
bahnstormer: do you have spacers on the front wheels too ?
I know that you said in first post that you got 1 set but from pictures looks diferent to me or is the front wheel in an angle :confused:
Can someone confirm me that the zenith 17" et is 54 ?
I know that you said in first post that you got 1 set but from pictures looks different to me or is the front wheel in an angle :confused:
Yes; 15mm spacers on front and rear.
I did a lot of research and measuring and one thing I found is that the rear wheels sit about 5mm inboard of the wheel arches relative to the front. Put the other way around; the fronts stick out slightly more.
And make it easier for the Mrs to curb my pegs?
Sadly, I'll pass (unless she gets her own motor again)
