Milltek, Where did you get yours?
Simple question, if you have a Milltek fitted, where did you get it from, how much and did they fit it, if so, how much did they charge?
Got it from Awesome with 10% off list during a promo, had it fitted at JABBA at the same time as the ARB, fitting was more expensive than expected due to problems with the sensor for the zennons and having to fabricate a bracket.
Got mine from Roadunner Motorsport in Nottingham. Was fitted by Geoff Bloor Garages for about £30
what was the problem with the sensor was it in the way what bracket did you have to have made up.
The Miltek sits closer to the axle than the oem system, and if the senosr is left in postion then it as a tendecy to rattle on the heat sheilding. It can be bent out of the way but that reduces the movement available in the sensor arm so they decided to fabricate a bracket to lift the sensor out of the way without altering the sensor arm angle.
Purchased mine on ebay £125.00.
Fitting was free by me and my boss.
Got mine from Roadrunner Motorsport in Nottingham
A full system?? £125??? what.... lucky boy
