water with oil
hi,
in case of engine (1.9 tdi) mixing water with oil what the possible cause of that and what should i do to fix it ?
thanks
Head Gasket maybe?
i changed it 2 months ago
+1 head gasket
most likely to be head gasket.
could possibly be leak in oil cooler?
Possibilities:-
1) Head gasket
2) Oil/water oil cooler leak
3) If you only do short trips, condensation under cam cover. In this case you might well find a mayonnaise deposit inside the oil filler cap.
