Drivers window
my electric window does not work the 2 switches do nothing took them off put a meter on the pins the switches work put a test lamp on the plug power found in one pin all so the electric mirrors don't move but they heat up any body any idea o the passenger window works fine it self:confused:
Not sure exactly what the symptoms are due to your dodgey spelling/grammar/lack of punctuation ;) but I'd be thinking:
  • Check the fusebox for blown fuses first
  • Check the wiring going from the drivers side switch
