Boost gauge wiring
I know similar questions have been asked before, but I haven't seen an answer anywhere - going to splice into the light switch wiring for my boost gauge, its mechanical so only need to connect a switched live and earth.
I'm going to connect into the wiring behind the light switch, but don't have a multimeter to hand. Can anyone that has already done this tell me which wire is the switched live? And is there a good earthing point somewhere behind there?
I have heard people saying about using the fusebox or relay board to tap into for a feed - whats involved in this? Exactly how would you use an empty fuse slot?
Ta
Andy
Hi, there is a relay under the drivers kick panel which Is marked 75x. This is switched live. There is a nut on it so you don't have to splice any wires, just fit a ring connector on the wire from the boost gauge:thumbup:
If you want it to light up with the instruments only - try wrapping it around the parking light fuse terminal on one side and replacing the fuse....
I have to appologise. I have misread the question like a plonker:rolleyes:
Ignore the relay solution as that is a switched power source in conjuntion with the ignition switch & will be no good for the illumination of the gauge. On mine I have linked into the sidelight wire behind the light switch.
Which colour is the sidelight wire?
The wire I tapped into behind the light switch was grey/purple. you could also tap into the grey/brown wire.
As these wires are before the fuse box I connected at the back of my gauges a blade inline fuse holder with a 5amp fuse for precautions. The holders are only pence from halfords & is a piece of mind.
