Jerky gear change from 1st to 2nd & 2nd to 3rd
Wondered if you could help me. I have an issue when changing gears from 1st to 2nd and 2nd to 3rd. Its very jerky as I engage the clutch.
I can control the jerk better using more revs on the gear change, but is becoming a little uncomfortable driving to work as its all stop start driving.
3rd to 4th, 4th to 5th is spot on.
I'm going to book her into the stealers today for sometime next week, see if they can find anything the matter.
With a bit of briskoda reading, Im thinking it could be one of the below:
Master clutch cylinder
Slave clutch cylinder
Gearbox oil needs changing
New clutch and flywheel (gulp!)
Gear linkages
Dogbone mount
Air in the clutch lines (Cheers, martziniuk)
Engine mounts (Cheers paul1978)
Gearbox mounts (Cheers paul1978)
Anyone else have any thoughts, so I can hit the stealers with what I think it could be.
Its an mk1 Octavia vRS:D
Cheers, Matt.:thumbup:
EDIT: Booked in for Friday 29th February.:thumbup:
What sort of mileage is it on? I'd probably start with checking the linkage, then maybe the oil change.
Ken, where is the linkage and how/where would we check it
Could it be possible that there is air in the clutch lines?
58k :thumbup:
ML, don't think it's likely to be oil then. Sticking with check the linkage, then maybe the dogbone.
I'd not think it's the clutch actuation though.
Fatty, the gear linkage runs from the bottom of the gear lever to the box. I think how to check it has been covered before; if it hasn't the best I could do is quote Haynes at you, and can't even do that today.
Cheers buddy I'll dig out the haynes when i get home :thumbup:
Check the engine mounts, especially the gearbox mount, this will cause excessive movement causing teh sytoms you've described.
Went out with the mechanic guys from Skoda who also drove a Octy vRS, he said he couldnt feel anything different to his, apart from a little extra power, He, He.
Had a brake fluid change and it does feel better, but maybe it was cycological, all in my head.:D
Glad your happy again Matt :thumbup:
