Annoying Squeak
I have a really annoying squeak coming from the front of my 2004 Octavia VRS.
It doesn't do it for cold but once the car has warmed up it starts, also it doesn't do it over every bump so I'm guessing that rules out suspension bushes.
I have done a search and from what I have seen on the forum it could either be a problem with the radiator mounts or the center section of the exhaust? Is there a simple way of testing these?
If you want to check your rad mounts open the bonnet and see if you can move your rad. As for exhaust you need to get under the car and check it
HTH
Thought that would be the case! Going to have to get my hands dirty at lunch time!
