Aerial on Fabia 3
I have just got my new Fabia 3 unfortunately the aerial hits my garage door so i have to unscrew it every time i drive in and out. I know this is a security aerial on the Fabia 3 that doesnt allow you to completely unscrew it. Does anyone know if its easy to take off or if Skoda supply a shorter aerial
Ray
Ray
IIRC, the aerial could be taken off through the courtesy light (from the inside)
By ClubSkoda
Thanks for the info I will give it a go
Well unscrewed it and gave it a tug but it doesnt appear to want to come off. How hard was it as I dont want to pull the housing too much as it will put a dint in roof.
make sure its unscrewed all the way, then just a short sharp tug will do it.
well i thought i had unscrewed it mate is it the threaded secion that comes away from the roof mounting?
yeah, the the actual aerial is attatched to the screw bit. you'll know when its unscrewed all the way it becomes more loose than you'd expect.
the other option is to just cut the aerial in half, quick/easy/cheap solution. not sure how good reception will be though.
yeah man but didnt really wanna do that as it wouldnt look that good. I thought i had unscrewed it enough as the pleanty of thread was showing from the aerial and it appeared completely loose did u hold the roof mounting when u tugged it?
no, just pulled,
may give it another go then this weekend
cheers mate
Am I missing something? My aerial just unscrews - take it off all the time to throrough the car wash??
Another option for you - after someone 'borrowed' the aerial of my Fabia replaced with the Richbrook Anti Theft Aerial from...
Speeding.co.uk Bee Sting & Assorted Aerials
Been fine so far and hasn't gone walkies! Has the added benefit of being able to be 'cut' to size.
