Engine management light on car runs ok
Sorry if this has been posted before
the em light came on this morning after 10mins
the car seems to drive ok
had a look there seems to be sludge in the air filter and oil breather pipe
cleaned this out but light is still on
if it is the maf sensor where would it be
1.4 16v classic 51 reg
many thanks in advance
MAF is after airbox and before rubber intake hose:)
thanks very much i will have a look
tomorrow and try and to clean it if poss
cheers
A common cause on the 16V is an EGR excessive flow code. This is often caused by a blocked EGR pipe under the throttle body which seems to contradict the excessive part of the description. I think that it describes it as excessive as the ECU winds out the EGR valve to the maximum to get the required amount of exhaust gasses into the inlet.
The first garage that you take it to will just want to renew the EGR valve at £100 or so when the first course of action should be to remove the throttle body and clean it and unblock the EGR pipe and if the fault code persists, then replace the EGR valve.
On the other hand it could be something simple like the engine coolant temperature sensor is faulty.
Get the codes read and come back to us.
i have changed the coolant sensor everything is ok
but why the oil sludge in air filter
head gaskett ok had that replaced in 2006
cleaned it all out and replaced the filter
done this before and the same thing still happens
car now runs very well more economical
cheers mark.
