ESP defective or not?
Hi
I found this fault with the VAG-COM
Address 03
Protocol: KWP2000
Controller: 6Q0 907 379 T
Component: ESP 8.0 front H03 0002
VAG-COM Version: Release 311.2-N
Control Module Part Number: 6Q0 907 379 T
Component and/or Version: ESP 8.0 front H03 0002
Software Coding: 0000296
Work Shop Code: WSC 13765
1 Fault Found:
16347 - Control Module
014 - Defective
Coding: 0000296
Shop #: WSC 13765
Can ayone tell me exactly what's this?
Otherwise the ABS,ASR,EDS seem to work fine....
Do you have ESP fitted?
Does the light come on?
If you clear the code does it come back?
Yes, the car came with original ESP
The light on the board appears only when the system is working ( ASR when pushing throttle to bottom the light comes on, EDS when the front wheels are on 2 different surfaces in terms of grip the light comes on)
The ABS is working for sure (tested on snow), but I never experienced the selective breaking with the "click" sound of the ESP (not even on snow testing - maybe I wasn't pushing enough....)
It seems that if I clear the code it's coming back...
This error is often a bad earth connection.
Check them, screw them off, re thread the thread, and re mount them, add some grease after.
Thats Skodas answer, i work at Vw,Audi and skoda.
Best Regards Morten
Best Regards Morten
Can you tell me exactly where to look for the ESP bad earth connections ?
MfG
Just follow the wires from the ABS block, theres a brown wire somwhere, that connects to the chassis.
seems that it was from the discharged battery...
  • 8 months later...
well more ESP issues:
I am positive that my ESP doesn't work
I have no errors on Vag-Com
ABS, TCS (ASR), EDS (EDL) work perfectly
The only one to blame is the ESP
What do you recommand?
Should I try a reinitialisation of the sensors?
How?
Details pls
I have the same problem with my Ibiza Cupra TDI and I'm nearly certain it's due to trying to start the car when the battery was flat.
ABS is working fine, the traction control light flashes when losing grip but doesn't actually kick in. I can't seem to get the ESP to kick in either.
Anyone know how to reset the ABS ECU as I'm sure thats all it needs?
VAG-COM results:
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 T HW: 6Q0 907 379 T
Coding: 0000299
Shop #: WSC 06403 785 00200
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
