ecu problem?
hi all. after reading quite a lot threads i'm sure i'm not the only person who's got problems with fabia's power steering. i've bought skoda fabia year 2000 1.4 mpi after a slight crash (it had a slightly damaged front bumper and one headlight needed replacement). my mate fixed all this but after that power steering light came on. there was no problem with steering for a couple of days though the light was on but later power steering cut off. then another couple of days later airbag light came on as well. i had a power steering sensor changed but that didn't solve the problem. i had a scan with vag-com done and you can see the report below. any ideas? please help
VAG-COM Version: Release 311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 047 906 033 C
Component: 1,4l SIMOS3PA 00HSSJ4A
Coding: 00021
Shop #: WSC 13765
TMBPB16Y713111768 SKZ7Z0Y0631855
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 35-10 - - - Intermittent
18056 - Powertrain Data Bus: Failure
P1648 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 09 -------------------------------------------------------
Controller: 6Q2 937 049
Component: BORDNETZ-SG. 2S04
Coding: 01032
Shop #: WSC 13765
4 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
01321 - Control Module for Airbags (J234)
49-10 - No Communications - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
01309 - Power Steering Control Module (J500)
49-00 - No Communications
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Y2 919 860 C
Component: KOMBIINSTRUMENT VDO V07
Coding: 16441
Shop #: WSC 28059
3 Faults Found:
01314 - Engine Control Module
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 2S04
Coding: 00012
Shop #: WSC 13765
3 Faults Found:
Have you tried to clear these off first?
Looks like someone has unplugged something with the ignition on.
It looks like that the power steering ECU has lost all communications, with that showing as the only non intermittent fault plus the lack of a scan on address 44 would confirm it for me. It could have lost communications for various reasons, a wiring fault, either for the power supply, earth or CAN Bus wires or an internal fault (expensive) with the combined pump/control unit.
Was the damage area on the left hand headlamp?, as that is where the PAS unit is situated.
