Wheelnut caps
So if you're ever stuck at the side of a motorway with a flat tyre just how do you get the plastic nut covers off the damn wheel:confused:
I spent ages at home trying to do it with the wire thingy in the toolkit (thick wire bent into a loop with a hook on the end) as the only item that would have been to hand in a real emergency until resorting to a tool in my garage (a flat bladed screwdriver bent over 90 degrees at the end) that will now reside in the boot.
The handbook shows a tool similar to a fuse puller but that isn't in my kit in the boot and I can't see a slot for it in the moulding the tools are in anyway.
I'd have been stuffed in a real emergency and would have had to rely on the AA
What type of wheel caps do you have, sounds like you have the centre cap puller not the nut cover puller.
as seen here bottom left...
My '07 vRS came with this type; they are quite easy to use and a complete set can be found from time to time on ebay; see here;-
Audi VW Wheel Lug Nut Caps/Bolt Covers A3 A4 A6 TT Golf on eBay, also, Audi, Car Parts, Cars, Parts Vehicles (end time 26-Mar-08 19:00:36 GMT)
You ought to be able to get the 'fuse puller' thingy from you dealer for a small price; but perhaps a new set would be better.
Thanks peeps
That looks like them on the left with the missing tool. Might just give dealer a call and see if I can get just the tool and how much otherwise I may get the set advertised and get nice new nut covers on the car - only thing is they look grey in the photo and mine are silver
You can usually get black, grey or silver. Long and short.
Loads on ebay.
Mine has a little hook in where the jack is. It is in a little slot of its own.
So if you have the caps above you have the wrong tool.
They look pretty similar to those above.
I have both tools in my Octy tool kit the wire one and the on shown above bizarre!
The wire one is carp since if you slip when trying to get the cap off you can scratch the alloy :(
Yeah, but its meant for a centre cap with a hole in it, not nut covers.
Yep I know the sort - had them on my Golf I think if I recall. I wonder why I have I got the wrong one then...?
Quite a few cars do end up with the wrong ones. Basically every car gets the wire hoop. The plastic nut covers come in a seperate bag with the removal tool. This either doesnt get put in the car on PDi (I have a fair few in the toolbox myself I must admit) or the valeters throw it away before delivery.
I got the wrong tool in both my Fabia VRs and Octavia VRs (wire instead of plastic) The plastic tool costs about 70p from the dealers (it was certainly < £1).
During the hand over the salesman at my dealers noticed that the nut cover puller was missing. Nice man supplied one in an instant only for us to find the original in the glove box, which he took back. I know it is an outside chance but have you looked in the box?
I've had my car nearly two years so I think I would have noticed one in the glove box :)
Will those exact covers fit pegasus alloys on an Octy 2?
Yes; they will. I have used them with Pegasus wheels.
It is more a case of the cover fitting the wheelnut, regardless of which wheels you have.
Go to your friendly VW dealer and buy a set of caps for a Golf. IMO they look far better than the standard Octavia grey ones. As a bonus the wire tool you've got will remove them! Don't forget that the caps for the locking bolts are different inside.
Hmm i better check mine now and see what its got.
