help please
hello i have a 53 plate octy vrs twin turbo ?? maybe and the cruise controle no longer works cant find a fuse or relay so i need help . or is this a dealer fix
Check your brake light switch.
Are you sure it's Twin Turbo??
Anyway I have repleid to your other thread but as Q says the Brake light switch is a good start.
What you really need is somone with VAG-COM to help diagnose it and from just glancing at your welcome thread you are Southampton based so that might kinda be in my vacinity :P
have checked my rear brake light all working as it should . lady at dealers said its the twin turbo version my wifes car so i dont get to drive it much so i dont know goes vwery well though
Brake lights may well work, doesnt mean the brake light switch is fully functioning.
Deffo just the one turbo in there.
sounds like u got sold with your twin turbo skoda
mine also stopped working cause of the clutch pedal switch always showing engaged, just needed adjusting
Wouldn't happen to be a lady from Sparshatts in Fareham would it??
I would really love to see a twin turbo vrs, bet it would go like fooook.:eek:
its defo your crankshaft journals happened to my twin turbo :thumbup:
I would suspect the stalk :)
the stalk only engages if you rag it for 5 mins and extract the creamy fluid.make sure you dont get the fluid in you eyes though it makes you go blind
defo crankshaft journals id put my left nipple on it been the journals
