Steering angle sensor calibration?
Hi again!
I've fitted Eibach's and I know I've seen how-to calibrate the steering sensor after wheel alignment. But now I can't find it anywhere... Am I blind or what? :eek:
Chris
You need VAG COM to do it.
Yes I know need VAG-COM but I meant those instructions how to calibrate the sensor with VAG-COM...
Chris
Nobody has any clue??? Not even VRSTU??? :confused::confused::confused:
Do you need to do this after fitting Eibachs?
I've never heard of having to do this after fitting springs.
Is this advisable ?
Or just a precaution ?
I think the calibration has to be done. At least now my steering wheel is a bit off but I'm going for a wheel alignment next week. Even a small difference may affect ESP... Yes I noticed the Ross-Tech but are the login codes same for Fabia. But still I'm pretty sure that I've seen instruction spesific to Fabia.... :) Well I think I get it sorted...
  • 2 months later...
Hi everyone. I'm trying to fit an angle sensor but I'm a complete novice really. I don't know anything about VAG-COM (how to get it and how to use it) and I don't know about this calibrating business. If I change the angle sensor on my Fabia (W reg 2000) 1.4 MPi Classic will I need to calibrate it?
Thanks everyone
Do you mean the power steering sensor? If so, have a read of the excellent guide below on VRStu's site.
Fabia-vrs.com - Replacing the Fabia PAS sensor
Thanks everyone
No, the ESP angle sensor and the PAS sensors are different.
