vRS exhaust question
Does anyone know if the back box has the same mounting points as a standard PD130 Ibiza? Also, is the pipe bore diametre the same so they can be cut and shut together? I have a garage that will do all the welding so thats not really a problem!
I know the bore diameter of mine 55mm and I'm sure that the VAG coupling sleeve used across the range is for 55mm pipe! Any help would be much appreciated!!
Yes mate it should fit.
They are all based on the same system design, and with all of the same sized fittings.
I would allways measure and compare before i tried it though.
michael
