Small inside briskoda sticker!
This is my second briskoda sticker (my first went with my old fabby :()
Anyway, I cleaned the window and made sure it was all prepared for the sticking!! Stuck it on and away I went!
But the next day it was on my parcel shelf :( It had fallen off!
So I stuck it back on, and this time it stuck for 2 days before falling off, soooooo...
What can I do to get my briskoda sticker to stick? :P
Stick it on the outside !
Thought the Brisky stickers were external only :confused: - mine is.
SI
I had the same problems, so now I don't have them.
is it one of those non sticky ones? maybe wet the window 1st is what ive had to do in the past.
No, it's definitely a sticky one :D
Apologies :ashamed:
That's internal for sure. Perhaps try wetting first - used to work on my tax disc holders.
Si
Had the same problem with the 2 I fitted but just the last 25mm curls up on both.
Tried wetting but curled up again. Now permanent curl!!
Could selotape I suppose but that may look a bit naf!
I don't think wetting it will work as it definitely has some sort of adhesive on one side, water would surely just render the adhesive useless?
I was thinking perhaps getting a larger piece or clear sticky plastic or something to hold it on, if you get me?
tbh id leave it off then as anything like what youve suggested will look cack imo
This happened to me too :(
Well it would be slightly larger than the existing sticker, and clear, so you wouldn't see it? ...
No Nails..............Works a treat..:)
:rofl:
you would see if unfortunatly but then aslong as there are no bubbles it should be fine and make sure you trim the tape to it looks right. it may go yellow though after a while.
Same thing happened to mine, must have pressed it back on very firmly half a dozen times before it gave in and stayed in place.
IIRC, there was a problem batch of these. My first one that was supplied as part of Freedom started curling a little in the edges after a few months.
I PM'd JohnD about it and he sorted me another. That's been fine ever since. So might be worth a PM?
Steve
The one pictured in the shop is mine and has been fine, stuck there well enough, no curling. The one I have is a cling type rather than stick sticker so is probably best to clean the glass well and leave it to dry.
