Testing for a signal from cruise control.
I read recently that it's possible to use vag com/vcds check to see if the ECU is recognising when buttons are pressed on the cruise stalk... Does anyone know if this is correct, and if so, how?
Thanks :D
Look in the label file for your ECU and you'll find a list of MBV's that are numbered, choose the ones you wish to look at and then view them in Measuring Blocks.
Thanks Stu, Just been having a play. What a cracking bit of kit vagcom is!
A lot of people under estimate it as a tool.
